RandomDave
Oct 06, 2025Aspirant
PLP2000 upload speed is slow.
Hello Netgear community! I've recently installed a PLP2000 kit. The download speed is fine (120Mbps) but the upload. Not so much. .4-2Mbps. Wired to the router I'm getting 1-1.2Gbps down and 4...
Oct 07, 2025Guru - Experienced User
have you tried thees powerline devices on the same circuit? It wouldn't be the first time that interference or circuit separation (running through an ARC fault circuit) reduced speeds
