Jon-L
Nov 11, 2021Aspirant
PLW1000 Extend Router WiFi for Apple Phone “Mobile WiFi” connectivity
I have a rural property My Apple phones antenna is unable to communicate with the closest cell tower. The only building on the 11 acre property is a steel shed. I have a cellular modem router locat...
- Nov 12, 2021Hey, thanks MichaelK
After investigating and learning oboist “Mesh Systems” I agree that mesh systems look perfectly tailored to my needs of a single broadly expanded network.
So now looking at Netgears:
A) Nighthawk mesh system6
B) AXE11000 WiFi Mesh System (RBKE963)
Thanks for guiding me towards the Mesh System as the correct network solution
JonL
Jon-L
Following on:
I haven’t purchased the PWL1000 yet.
I’simply want to make sure the PWL1000 is the right product. By all accounts, it appears to be.
My network skills are only at the “follow these steps” level.
I need to avoid having my “mobile WiFi” call disrupted went I move from one side of the steel wall to the other.
I am also contemplating purchasing some property equipment that can be controlled from my phone, but to work the equipment needs to be connect to the same network as my phone, which is connected to me cellular modem router.
