KateStitch's avatar
Aug 22, 2019
PLW1000 suddenly stopped providing internet
I have a laptop set up in a detached building on our property. The PowerlineV2 box is connected via ethernet to our Xfinity router. The adapter in our garage to serve as a bridge. I was getting a str...
  • michaelkenward's avatar
    michaelkenward
    Aug 23, 2019
    KateStitch wrote:
    Should I do a factory re-set and start all over?
    That would seem to be the only option.
    You could try plugging the laptop into the plug. If it has a LAN port, of course.
