GromitD90
Aug 02, 2020Aspirant
PLW1000 Telnet Access
Hi, I'm hoping someone can help me with this issue with my PLW1000. I am developing a program for my own use that will periodically attach via telnet to each of the 4 WiFi Access Points in my ne...
chainz316
Jul 11, 2022Aspirant
Im trying to telnet into my plw1000 to change the region from being locked. When I try to telnet it says it cant connect to port 23, any idea what port to use?
GromitD90
Port 23 is usually the one used for Telnet. I was never able to get it to work after my initial attempt described above. I ran a port scan against mine and the only open ports were 80 and 1050 which are both used for http. So I would say that there is no way to Telnet into the PLW1000.
IMike
- chainz316Jul 11, 2022Aspirant
hmm but you managed to telnet in ?
I wanna run the burnsku command to change region apparently its the only way to do it
