Bubber's avatar
Bubber
Follower
Feb 05, 2016
PLW1000 vs 1010
What is the difference between these two products:
http://www.netgear.com/home/products/networking/powerline/PLW1000.aspx
http://www.netgear.com/home/products/networking/powerline/PLW1010.aspx
I did a side-by-side comparison of the two, and they seem identical as far as their spec sheets go, except that the latter one is labelled “Essentials Edition”, whatever that means.
Also, has the 1010 been released yet? The product is listed as unavailable at all of the online stores under “BUY NOW”.
  • I can't see any difference either at the moment, although the 'Essentials Edition' versions are generally stripped back a little from their original versions, but for this they are often a little cheaper in price
    • JamesGL's avatar
      JamesGL
      NETGEAR Employee Retired
      Hi Bubber,
      They have the same technical specification. No difference at all.
