jabbado
Aug 10, 2022Aspirant
PLW1000v2 working fine but "Pick a Plug" LED not lit
I recently purchased a pre-owned PLW1000v2/PL1000 v2 from a friend, to get internet into the shed. It works fine. The link speed hovers around 300Mbps which is adequate for my usage. But the Pick A P...
- Aug 11, 2022
If everything is working fine, its probably a led issue.
Aug 11, 2022Guru - Experienced User
It its working, I wouldn't worry about it.
- jabbadoAug 11, 2022Aspirant
Yeah so do you think it's just the LED isn't working/broken? The Pick A plug light on the host PL1000 adapter is lit green. I upgraded to the newest firmware yesterday and it didn't fix the issue.
- plemansAug 11, 2022Guru - Experienced User
