decksw87
Jul 19, 2020Follower
Power Line Adapter 2000
Alright have a powerline adpater 2000 From netgear, No matter what i do i get an unidentified network. Which cannot be set to privete in windows 10 so dont even suggest nor is the issue since other n...
michaelkenward
Jul 22, 2020Guru - Experienced User
It is near on impossible to understand what you are talking about here.
Take this bit.
What is telling you "unidentified network"?
Then tnhus:
decksw87 wrote:
Which cannot be set to privete in windows 10 so dont even suggest nor is the issue since other netgear powerline adapters work on the same network.
What does that mean?
What cannot be set to private in Windows 10?
Take us through what you are doing and where it goes wrong.
