Mellowish
Jul 26, 2023Follower
Power line adapter with an old house that has a sub panel and outbuilding
I’m trying to get internet to my office that is about 100 ft from my house. My house is about 120 years old. There are two circuit boxes that are connected. The old box is a 100w box connected to the newer 200w box. The outlets near the router are wired to the old box.
Also the office is wired into the new box into 1/2 of a 220 breaker. Don’t know why the electrician did that.
When I set up the power line adapter, it will not work in the office. I get a Wi-Fi signal but no internet. It works with every other outlet in the house but not the office.
Any suggestions?
Any suggestions?
Also the office is wired into the new box into 1/2 of a 220 breaker. Don’t know why the electrician did that.That layout looks like a recipe for disaster. Powerline signals find it hard to cross all those junction boxes without losing signal.
My setup is similar to yours. Ancient house with its own fuse box and isolator feeding a separate building with another fuse box. Powerline works but too slow to be usable.
Then there is the 100 feet distance. LAN can stretch that far, but probably not Powerline or regular wifi.
In my case, I went for a separate Internet service and phone line for business use. All tax deductible.
If you're within line of sight, you could use a point to point system like netgear airbridge (not usually in stock) or another brand of point to point system. They work pretty good and shouldn't have issues crossing 100ft.
Or you could bite the bullet and just run the ethernet wire. In the long run, its much nicer to connect them but can be a hassle to run.
The best option.
After all, there is already a power cable between the two places.
I am lucky, my overhead power cable runs just 10 metres or so, and it still struggles with powerline.
