Arkj
Jan 06, 2021Follower
Power line compatability
Hello, I own the model quoted, I currently have 2, input and output. I'm looking to expand my powerline net work, I dont know where to find a compatability list for my current set up. Is...
- Jan 06, 2021You can mix/match powerline adapters (even between manufacturers) provided the follow the same standard. The XAV2001 was a homeplug AV1 device. You can use homeplug av2 devices with it but they're going to operate at the slowest devices speeds. Which for the xav2001 is a 200mbps device.
read more about the home plug spec here: https://en.wikipedia.org/wiki/HomePlug
Jan 06, 2021Guru - Experienced User
