KeithI's avatar
KeithI
Power line Query
I'm trying to get internet to my garden workshop primarily for a CCTV camera (Swann) and not having a lot of luck with Wifi.  The workshop is about 40m from my house and probably 50m or so from my router.  I have a Netgear Wifi Mesh extender AC1900 that sits in my conservatory about 30m from the workshop and has a good connection to my home wifi, but I'm not convinced I'm getting a reliable connection at the workshop end.  I have a powerline 1000 plugged into my mains and computer via a cat5 cable and I wonder whether a repeater in the workshop would be a better option. What are the requirements for this?  Do they need to be on the same side of the consumer unit and will going through the consumer unit in the workshop affect the performance?  I'd be grateful for any advice re this and what would be the best kit.  Cheers..
  • michaelkenward's avatar
    michaelkenward
    AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    I can't work out how far anything is from anything else in that description, but wifi has its limits. 50 metres is pushing many systems. Maybe an Outdoor Orbi satellite would help. (They can also work on their own without an Orbi router.)
    Lots of things get called "repeaters" so I don't know what this is either. Or where these Powerline devices are in that array of stuff. But Powerline also has its distance limits, especially if separate buildings have their own fuse boxes and breakers. Powerline devices don't like negotiating those.
    I have used Powerline to create a connection between a router and an Orbi system.
