Zanzibar's avatar
Zanzibar
Power line
II have already istalled the Power line Adaptor to my router and the relevant Access Point WiFI Power Line Netger to a eletrical wiring netwprk.  Now i  need to install one more adapter to increase W...
  • plemans's avatar
    May 24, 2020
    You could go that route or you can buy a compatible adapter. The powerline devices use a specific standard and should all work together within that standard. So the plw1000 is homeplug av2 compliant. so any device compatible should work fine.
    https://en.wikipedia.org/wiki/HomePlug
