Zanzibar
May 24, 2020Aspirant
Power line
II have already istalled the Power line Adaptor to my router and the relevant Access Point WiFI Power Line Netger to a eletrical wiring netwprk. Now i need to install one more adapter to increase W...
- May 24, 2020
You could go that route or you can buy a compatible adapter. The powerline devices use a specific standard and should all work together within that standard. So the plw1000 is homeplug av2 compliant. so any device compatible should work fine.
May 24, 2020Guru - Experienced User
michaelkenward
May 25, 2020Guru - Experienced User
That's what I did when I wanted to add a new device to my Netgear powerlines.
Most of the brands sell only bundles, not singletons allowed.
I ended up with a Devolo twin LAN plug. Works just fine. Not wifi though.
Remember, you need just one plug connected to the router.
