Markneedshelp
May 10, 2021Aspirant
Powerline 1000, can I connect anything to make wifi better
Hi, I have purchased a Netgear powerline 1000 to get a wired connection to the upstairs of the house, as the wifi doesn't reach too good. Whilst that works great for one computer, I wondered if t...
May 10, 2021Guru - Experienced User
Or you can simply add a router (in access point mode) or an extender in access point mode to the powerline device.
Many routers/extenders have multiple ethernet ports and support wifi. So you'd be able to hardwire in or use it wireless.
- MarkneedshelpMay 10, 2021Aspirant
Hi,
Thanks for the reply which is really helpful, much appreciated.
Kind Regards
- michaelkenwardMay 11, 2021Guru - Experienced User
Many routers/extenders have multiple ethernet ports and support wifi. So you'd be able to hardwire in or use it wireless.I'd go down that road.
The powerline plug's built-in wifi won't be the most powerful around. And you can't buy a single plug, so you end up buying a bundle with two plugs. Unless you need the extra wired plug, you can end up shelling out as much as you'd pay for a single wifi extender that you can use as an access point.
I have an Orbi router at the end of a Powerline network. Way better than any Powerline AP and with a raft of LAN ports that I can use for other things.
