Markneedshelp
May 10, 2021Aspirant
Powerline 1000, can I connect anything to make wifi better
Hi, I have purchased a Netgear powerline 1000 to get a wired connection to the upstairs of the house, as the wifi doesn't reach too good. Whilst that works great for one computer, I wondered if t...
May 10, 2021Guru - Experienced User
Or you can simply add a router (in access point mode) or an extender in access point mode to the powerline device.
Many routers/extenders have multiple ethernet ports and support wifi. So you'd be able to hardwire in or use it wireless.
Markneedshelp
Hi,
Thanks for the reply which is really helpful, much appreciated.
Kind Regards
