Kenssonhs
Aug 08, 2023Aspirant
powerline 1000 ethernet connection suddenly can't get a network signal
So everything was working great...until it wasn't. I have four units plugged in to the mains in various locations. Suddenly, I can't get a network signal on my smart TV. I have changed nothing in ...
schumaku
Aug 13, 2023Guru - Experienced User
Kenssonhs wrote:
So everything was working great...until it wasn't. I have four units plugged in to the mains in various locations. Suddenly, I can't get a network signal on my smart TV. I have changed nothing in the network.
The third light on the adapter blinks green while the two above are solid. I presume that means something is transiting the ethernet cable, but my TV says there's no network connection.
Ken,
Here the LED information of the PLA2000 devices-
To me, the side note of an eero router made me wondering. Is this box newer in this set-up?
Kenssonhs
Aug 14, 2023Aspirant
Yes, this is the last unit added to the network. However, it is only a few months "younger" than the original two units. Additionally, it had been working fine for more than a year before I encountered the issue to which I referred in my original post.
- schumakuAug 14, 2023Guru - Experienced User
Not a question of the age ... more a question on the network structure and connection of all the devices. Adding a random NAT router like the eero is a recipe for a nightmare, or at least to something causing unwanted network segregation.
Difficult, because you seem to navigate around instead of bringing the complete network design and implementation on the table. Impossible to help, frustrating for everyone trying to help.
- KenssonhsAug 14, 2023Aspirant
Perhaps I could be more responsive if I understood what you mean by "eero." I have never encountered that abbreviation in any scenario. Let me try a more detailed description. Apologies if I use non-typical terminology, as I am not tech savvy:
I am on Fios. I use one of their wifi routers, located on the second level of my home. I have an ethernet cable (hereafter, EC) running from the router to the first powerline adapter. The second adapter was installed in the basement to connect a PC. I added a second adapter in the basement to connect another PC. The fourth adapter was added last on the main floor for the purpose of connecting my TV, which, as with the two PCs, is linked to the adapter via EC.
Until about a week ago, I was not experiencing buffeting issues on the TV. Suddenly, I was experiencing occasional buffering even using the powerline system. Thereafter, the TV lost connection to the network altogether. Even so, the PCs still maintain their connections. That seems to suggest the problem either lies with the adapter itself, or perhaps the EC. I do not have a spare cable so I have not been able to swap it out. I did try changing the electrical outlet, but to no avail.
Hopefully this is sufficiently detailed to be helpful. I'll be happy to respond to additional questions. My hope for posting is to garner info on other alternative solutions beyond those I have already attempted.Thanks.
Sorry, probably I had another thread in my mind? eero is a brand with various products that allow for Wi-Fi to reach all areas of a household.
