CMcMeins
Oct 06, 2019Aspirant
Powerline 1000 Pick A Plug Won’t Light Up
After redoing a room I am setting up my adapter again, there was no work done on the power lines and a month ago it was working perfectly fine, but now it won’t connect no matter what I do. I have res...
Oct 08, 2019Guru - Experienced User
things that can cause interference/poor signals with powerline include arc fault breakers, gfci breakers, surge protectors, high draw motors/appiances, cell phone adapters. Basically any of these can add interference to powerlines. You might have been at the far end of the range for your powerline devices and something like a bad cell phone charger or motor going bad added enough interference to the line to cause the issue. When they connect in the same room (same circuit) but not when they're on different circuits, it usually means something within your home added interference to the lines.
- CMcMeinsOct 09, 2019AspirantThat would be helpful but nothing has been added, I’m putting it into the same socket as before, same device, same everything. The only change that has occurred is less stuff is plugged in, there were a lot of things that were plugged in but never used, other than that no other changes have been made.
- plemansOct 09, 2019Guru - Experienced User
again, devices go bad, motors start going bad.
If its working on the same circuit something within your home is adding interference to the wiring.
Try taking it to someone elses house and seeing if it works.
