CMcMeins
Oct 06, 2019Aspirant
Powerline 1000 Pick A Plug Won’t Light Up
After redoing a room I am setting up my adapter again, there was no work done on the power lines and a month ago it was working perfectly fine, but now it won’t connect no matter what I do. I have res...
CMcMeins
Oct 09, 2019Aspirant
That would be helpful but nothing has been added, I’m putting it into the same socket as before, same device, same everything. The only change that has occurred is less stuff is plugged in, there were a lot of things that were plugged in but never used, other than that no other changes have been made.
Oct 09, 2019Guru - Experienced User
again, devices go bad, motors start going bad.
If its working on the same circuit something within your home is adding interference to the wiring.
Try taking it to someone elses house and seeing if it works.
