Lauren19
Dec 31, 2019Follower
Powerline 1000 plug to plug connection issue
I had my mini network setup working great with a unit I purchased about 6 months ago. Decided I needed an additional wifi access point, so I purchased an additional set. I plugged in the new wifi A...
michaelkenward
Jan 01, 2020Guru - Experienced User
Lauren19 wrote:
Decided I needed an additional wifi access point, so I purchased an additional set. I plugged in the new wifi AP and it seems to sync up briefly.
What is the network layout? You need just the one Powerline plug connected to the router. You then add the new plugs in the usual way:
>>> Adding a powerline adapter to an existing powerline network <<<
Do this to add the access point plug to the "host" plug on the router.
If you don't need the extra Ethernet only plug, just leave it out of the network. Or you could use it as another outlet after you introduce it to the host plug.
