thebook
Aug 09, 2019Follower
powerline 1200 extra PLP1200, where do I buy them
How do I get extra plp1200 conectors ?
michaelkenward
Aug 10, 2019Guru - Experienced User
Or you can see if you can buy singletons from another brand.
These things are supposed to be "AV" standard, so different makes should work together.
They do work together but not always at the same performance.
- michaelkenwardAug 10, 2019Guru - Experienced User
It certainly does not help if you mix speeds. AV500 and 1000 will talk at the slower speed.
Mixing brands can also cause headaches when trying to manage them with different interfaces.
