Sidchicken's avatar
Sidchicken
Initiate
Oct 21, 2020
Powerline 1200 Pick a Plug Blinks
Just installed my powerline 1200. The Pick a Plug slowly blinks green then red and repeats. The units are about 40 feet apart. What is wrong?
  • plemans's avatar
    Oct 21, 2020
    Try putting them on the same circuit. With home circuits all being wired back to a breaker box, them being 40 ft away could actual mean they're 100+ft apart depending on how the wiring is setup.
    And not all homes work well with powerline. Many things impact it such as:
    gfci outlets
    surge protectors
    arc fault breakers
    high draw appliances/devices
    cheap/old/bad/going bad electronics
    even cell phone chargers
    old or bad wiring
    These things can all add interference to the powerline system. So try them on the same electrical circuit and see if they work. If they do, its probably something adding interference as the further apart they are, the more issues it creates. But even if it still happens, doesn't mean it isn't something adding interference. It just means that device is adding so much, its even overwhelming individual circuits.
