Sidchicken
Oct 21, 2020Initiate
Powerline 1200 Pick a Plug Blinks
Just installed my powerline 1200. The Pick a Plug slowly blinks green then red and repeats. The units are about 40 feet apart. What is wrong?
- Oct 21, 2020
Try putting them on the same circuit. With home circuits all being wired back to a breaker box, them being 40 ft away could actual mean they're 100+ft apart depending on how the wiring is setup.
And not all homes work well with powerline. Many things impact it such as:
gfci outlets
surge protectors
arc fault breakers
high draw appliances/devices
cheap/old/bad/going bad electronics
even cell phone chargers
old or bad wiring
These things can all add interference to the powerline system. So try them on the same electrical circuit and see if they work. If they do, its probably something adding interference as the further apart they are, the more issues it creates. But even if it still happens, doesn't mean it isn't something adding interference. It just means that device is adding so much, its even overwhelming individual circuits.
Sidchicken
Oct 29, 2020Initiate
Still blinks but the connection has been established and is working satisfactorly.
michaelkenward
Oct 29, 2020Guru - Experienced User
Thanks for the confirmation. Good to know.
As plemans says, Powerline is particularly sensitive to local conditions.
