GotYourSix
Mar 25, 2020Aspirant
Powerline 1200 problem-not connecting anymore
I'm hoping I can find some help on here since I've been searching and searching and just cannot find a solution. I had gotten a powerline 1200 adapter so I could have internet down to my computer in t...
GotYourSix
Now what could the problem possibly be if I did move then to the same room/circuit but they still wont connect? Could it be an issue with the adapter itself and I would have to exchange for a new one?
Mar 25, 2020Guru - Experienced User
Potentially yes.
You could also try them at a different location. maybe whatever caused the issues is injecting enough interference that its even causing issues with them on the same circuit. Its worth testing as if you replaced them and it wasn't an issue with the devices, it puts you in the same boat.
- GotYourSixMar 25, 2020AspirantNo I haven't replaced them yet, and I've been unplugging devices to try and narrow it down to something that was plugged in but the set up I have right now I've had for the past couple months but all of a sudden it just quit on me and stopped working. Nothing was added or taken away which is why I'm throughly confused on what to do.
