cfoll
Feb 28, 2020Aspirant
Powerline 1200 Randomly No Internet
Hi all, Randomly durig my machine use I noticed I got kicked off ethernet to Wifi. Looked at my powerline status and it shows "Unidentified Network No Internet" despite properties coming through li...
cfoll
NOTE: pick-a-plug is now blinking green after trying to reset the device/config using troubleshooting steps
- michaelkenwardFeb 29, 2020Guru - Experienced User
Where exactly do you see this message:
Looked at my powerline status and it shows "Unidentified Network No Internet" despite properties coming through like the fact it can read this is a 1 Gigabit connection. Using the network troubleshooter I found,
"Ethernet" doesn't have a valid IP configurationIn a Windows PC?
- cfollFeb 29, 2020Aspirant
Yessir, Windows 10
cfoll wrote:
Yessir, Windows 10
That smells like a Windows networking issue.
Did you ever run the network troubleshooter?
Try this. Tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
