cfoll
Feb 28, 2020Aspirant
Powerline 1200 Randomly No Internet
Hi all, Randomly durig my machine use I noticed I got kicked off ethernet to Wifi. Looked at my powerline status and it shows "Unidentified Network No Internet" despite properties coming through li...
cfoll
NOTE: pick-a-plug is now blinking green after trying to reset the device/config using troubleshooting steps
michaelkenward
Feb 29, 2020Guru - Experienced User
Where exactly do you see this message:
Looked at my powerline status and it shows "Unidentified Network No Internet" despite properties coming through like the fact it can read this is a 1 Gigabit connection. Using the network troubleshooter I found,
"Ethernet" doesn't have a valid IP configuration
In a Windows PC?
- cfollFeb 29, 2020Aspirant
Yessir, Windows 10
- michaelkenwardFeb 29, 2020Guru - Experienced User
cfoll wrote:
Yessir, Windows 10
That smells like a Windows networking issue.
Did you ever run the network troubleshooter?
Try this. Tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
Yes, the troubleshooter is how I first found the message " "ethernet" does not have a valid ip configuration"
Unfortunately, I don't have the op[tion to change the ethernet to private connection only the Wifi I'm now having to use- michaelkenwardFeb 29, 2020Guru - Experienced User
Have you checked that you have the latest drivers for your Ethernet?
This sounds more like a Windows issue than anything to do with your Powerline devices.
cfoll wrote:
Unfortunately, I don't have the op[tion to change the ethernet to private connection only the Wifi I'm now having to useDo you mean that those settings are not available to you?
If so, even more evidence of a Windows problem.
What router and/or modem sit in front of the Powerline network?
