Raven_Glory
Dec 03, 2021Aspirant
Powerline 2000 causing interference with wireless headphones
I recently bought a second pair of powerline adapters, and in the process of setting up those I reconfigured my original pair of adpaters (plugging them directly into the socket etc) to improve speed...
michaelkenward
Dec 04, 2021Guru - Experienced User
Raven_Glory wrote:
Specifically left earbud of my Jabra Elite 75ts is barely able to connect when its in the same room as the powerline adapter, getting significantely worse as I move closer to the device.
Have you tried swapping the "noisy" plug for one of the others?
This might help you to work out if it is the plug or the socket that causes the interference.
Are these all PLP2000 plugs? Do you have four altogether?
Is there just one plug attached the router? (There should be.)
Raven_Glory
Dec 09, 2021Aspirant
I'm going to answer your questions in order :
Yeah, I have they're both pretty similar? I've tried 2 different plugs in 2 different sockets. The main difference seems to be how close the socket is to where I'm sitting.
Yes
Yes
