bc_kuma
Oct 18, 2021Aspirant
Powerline 2000 DL speed 5MBPS vs UL speed 100MBPS, why?
I have my PLP2000 wired to an eero mesh that's wired to the FIOS 1GB gateway and I get 5MBPS DL and 100MBPS UL when running network speed check in the other end. The eero results (DL/UL) are both in ...
bc_kuma
Thanks for your reply.
If I would have had DL speed just as the UL speed, I would be happy and content and that's why I asked why the two were so different.
What you wrote would affect both UL and DL speeds right?
Oct 18, 2021Guru - Experienced User
Potentially could. thats why its hard with powerline.
One thing you can try doing just to see if its a device issue is to put both powerline devices in the same room (tend to be on the same circuit) and test them to see if they get similar speeds up/down. that tends to eliminate a few of the things that inject interference so you can see if the devices are good.
