Jeremyk2157
Apr 23, 2021Aspirant
powerline 2000 is slow
Hi, I am very disapointed with the broadband speed over the powerline 2000 and am about to return it to the store unless anyone can help me resolve this issue. 2 days ago gigabit fibre was instal...
Apr 23, 2021Guru - Experienced User
Powerline devices are even more overinflated than wifi devices.
I'd read a few reviews on them about how they actually perform as well as how fast speeds drop off when powerline devices are on different circuits.
Smallnetbuilder has review quite a few of them (not sure if any 2000mbps devices) and its worth reading a few different devices performance.
https://www.smallnetbuilder.com/tools/rankers/powerline/view
michaelkenward
Apr 24, 2021Guru - Experienced User
Powerline plugs also seem to be more susceptible to local factors. Even the newest mains circuit can have something nasty plugged into it to interfere with the Powerline signal.
Powerline devuces were also designed in the days before Internet connections hit Gbps speeds.
Many people can only dream of getting 180Mbps. (Does a connection that "slow" really hinder anything anyone does? Or is this just a case of measuring speeds for the sake of it?) For most of us, still stuck with DSL internet, Powerline speeds are as good as we'll get.
To my mind, Powerline isn't there to replace proper Ethernet cables but to avoid the flakiness of wifi and to get a connection to places where I don't want to run wires. Powerline is a good way to connect a smart TV, beating wifi hands down for connectivity and ease of setup.
- Jeremyk2157Apr 25, 2021Aspirant
Hi Plemans,
Thanks for the response. You are right 180 Mbps is not slow and I admit I should have worded the subject differently and said the Powerline 2000 speed is disappointing.
I've done some more testing and am getting much faster speed when the pl adapter is in the next room to the router, I'm getting about 290Mbps download and up to 400 upload so I assume now I'm on the same physical electricity circuit whereas previously I probably wasn't.
I know these speeds are great compared to DSL where I was getting 60-100 download, my gripe is that I get 900+ at the modem and on the Powerline 2000 box it states 'Extremely fast gigabit speeds', that's why I paid $200 NZD. I've got a support ticket raised with Netgear but I suspect I'll return the adapters and run ethernet under the floor.
btw wireless from my laptop is 187Mbps download, 135 upload - sweet deams :-)
- plemansApr 26, 2021Guru - Experienced User
If you've got the option of running ethernet, its going to out perform powerline/moca/ any day.
Highly worth it especially if you run it your self.
