kahliloppenheim
Jun 11, 2020Follower
Powerline 2000 LEDs wont turn on
Hello :), I bought two Powerline 2000 adapters and one month ago. I set them up and they have been working as expected, transmitting reasonable ethernet speeds. However, just recently, one of...
- Jun 12, 2020
kahliloppenheim wrote:
However, just recently, one of the two adapters stopped working completely. The LEDs no longer turn on when it is plugged into the wall.
If it still does the same thing when plugged into a socket near to the router plug, then it might have died. In that case, a warranty return might be in order.
Remember, the LAN LED will not come on if nothing is plugged into the LAN port, but the other LEDs should show.
michaelkenward
Jun 12, 2020Guru - Experienced User
