Saraski
Feb 06, 2021Tutor
Powerline 2000 RED pick a plug
We have had 3 of these adapters for 2 years now, never a problem. Today, with zero configuration changes, new appliances, etc, the Pick A Plug is red on all of them. I have moved them around, restarte...
Feb 06, 2021Guru - Experienced User
If you put 2 of the adapters next to each other (primary connected to router and 1 other) do they connect?
Its not always something you changed, its something else changing. The powerline devices work over the power network and if an electronic device is going bad, it could be injecting interference into the powerline system. The best way to test is to put 2 next to each other on the same circuit. That'll give them the best possible connection
- SaraskiFeb 06, 2021TutorThanks for the reply. I’ve moved them into all kinds of configurations but still only red lights.
