Yootington
Dec 30, 2021Aspirant
Powerline 2000 uPnP not working on Xbox One
Have setup my PLP2000 in my house. Modem is downstairs and PLP is plugged into it. My room is upstairs and the other PLP is plugged into my wall and I've connected it to my Xbox One via Ethernet cable...
Dec 30, 2021Guru - Experienced User
The PLP effectively acts as a ethernet line through powerline. It doesn't have those functions built in. They're all controlled from the router.
You'd have to contact your router or xbox setup for that.
If the powerline device is connecting and working, its doing its job. Thats all it does.
Yootington
It's not connected to a router, it's connected directly to the modem. Would I have to look at the settings for my modem?
- plemansDec 30, 2021Guru - Experienced User
If that modem is a modem/router combo device then yes.
