Hrusovsky
Mar 18, 2020Follower
Powerline 2000
I am connecting my Powerline 2000 to get higher speeds for a gaming computer. I have a modem which is direct wired to the cable/internet company. This is hooked up to a Netgear Wireless Router. Ho...
antinode
Mar 18, 2020Guru
> Powerline 2000
> Model: A6150|AC1200 Dual Band WiFi USB Mini Adapter, PLP2000|Powerline
> 2000 + Extra Outlet
Is there an A6150 involved here? Is the actual model number of the
Powerline device "PLP2000"?
> [...] I have a modem [...]
Has it a maker and model number?
> [...] This is hooked up to a Netgear Wireless Router. [...]
Has this router a model number? Where are these devices situated?
> [...] my Powerline 2000 [...]
> [...] the Powerline 2000 [...]
Do you have _one_ Powerline adapter?
Visit http://netgear.com/support , put in your (actual) model
number(s), and look for Documentation. Get the User Manual(s). Read.
> [...] to get higher speeds for a gaming computer. [...]
"higher" than what?
> [...] How do I connect the Powerline 2000 - into the modem or into the
> wireless router, or both?
You might connect a _pair_ of Powerline adapters to any two devices
(one adapter to each device) which you wish you could connect using a
simple Ethernet cable.
If you're trying to use Powerline adapters to connect your
(unspecified) "a gaming computer" to your router using a pseudo-wired
connection (instead of a wireless radio connection), then you'd connect
one Powerline adapter to a LAN Ethernet port on the router, and another
Powerline adapter to an Ethernet port on the (unspecified) "a gaming
computer". Read the User Manual for the Powerline adapter. Really.
Also of possible interest:
