imgoingtokermit
Apr 22, 2019Follower
Powerline 500 WiFi XWN5001 + LOST admin password, help.
I've forgotten the admin password. I cannot find the admin password. Is there any hope for finding the admin password or am i totally effed?
Apr 22, 2019Guru - Experienced User
Did you change the default password? If not, its password
If you did, its pretty easy to reset the device and set it up back up. It'll revert you to default login and password. Just hold the reset button for 7-10 seconds. You'll then need to go back through the setup procedure. Here's the support page for your device. it'll have the manual and firmware for your device.
