tharries20
Apr 16, 2012Follower
Powerline adapter not turning on?
Hi I Have used the Netgear Powerline AV 200 Adapter Kit for a little over a year with no problems. We recently came back from holiday however to find the power out in our study with our wifi router, ...
clithes
May 19, 2012Prodigy
I would suggest that if you had to reset the fuse something has triggered this, which could have been the unit failing, a power surge or even a lightning strike. The components are fairly sensitive so I would think its fried unfortunately
