Flappy_asdf
Jun 01, 2020Follower
POWERLINE ADAPTER NOT WORKING AND NEEDS FIRMMWARE UDPATE I CANNOT FIND IT
I have looked around and cannot find the firmware update for this model, it does not work and I cannot connect to any devices as it does not give an ethernet connection. I need to update the firmware...
michaelkenward
Jun 02, 2020Guru - Experienced User
Flappy_asdf wrote:
I need to update the firmware but cannot find it I need help.
Powerline technology isn't the same as routers. It is essentially a bit of wire.
Firmware is mostly there for plugs with wifi.
Apart from that it is "dumb" technology. Plug it in and it should work. If not, something else is happening. See what plemans says.
If you want more advice, tell us a bit about what is happening at your end.
Take this comment:
Flappy_asdf wrote:
...it does not work and I cannot connect to any devices as it does not give an ethernet connection.
We need a bit more than "it does not work".
What are you doing and where does it go wrong?
Here at least, PL1000s were a doddle. Plug into router, then plug into remote socket, attach access point, bingo. I had to do nothing else.
