JS2989
Mar 26, 2021Aspirant
powerline adapter v extender
I"m moving to a larger house and dont know if it's better to get a powerline adapter and attach a router to it (does that work) or to get an extender. Thoughts?
michaelkenward
Mar 28, 2021Guru - Experienced User
As plemans says, your message amounts to "how long is a piece of string?".
As well as their questions, you could also add say something about the equipment you have now.
JS2989
Mar 28, 2021Aspirant
The house is about 4500sf across 3 levels. I need good connectivity on all three levels for two home offices and two middle schoolers w remote schooling, as well as a need for zwift. I don't know what the walls are like bc I don't close on the house until tomorrow. The house was built in 2008.
I recently bought an nightwahwk X6 R8000 router.
I also have an EX7300 (v1... bought more than 4 years ago). It seems to work ok in my current house but I can't figure out if it can have the same name as the router instead of haviing the _EXT added.
for the new place was thinking about the EX8000.
suggestions welcome!
- michaelkenwardMar 28, 2021Guru - Experienced User
Sounds like shooting in the dark. Start with what you want to do rather than ideas about equipment.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
