PatDofNJ
Dec 18, 2020Aspirant
Powerline adapters and wifi extenders not showing up in network map
I have two Powerline kits on my LAN (a Powerline 200 adapter and wifi extender and a Powerline 500 adapter and wifi extender) but only the Powerline 200 shows up on my network map when using the Netg...
LeckyNeil
Feb 02, 2021Aspirant
I have two XAV5601 and one XAV5501 adaptors all on the same network, and they work fine. However, the Powerline Utility D 3.1.0.4 only ever shows two adaptors even when all three are switched on and working. Please can you explain why this is?
- michaelkenwardFeb 02, 2021Guru - Experienced User
Not really. What you want to do with the Powerline utility?
It is effectively dead. (Your plugs are also pretty old.) It doesn't even support newer models.
If I want to do anything with the plugs, which is not much. (They are just plugged in and doing their stuff.) I use the desktop genie program.
Powerline Network Map
For fancy moves, I might dig out one of the programs from alternative brands, ZyXel or devolo. But, like I said, what is there to do?
- LeckyNeilFeb 02, 2021Aspirant
Thank you for your rapid reply.
I didn't know about the Genie software, I will try that.
The Powerline Utility was originally useful in checking whether the network was working as it should. This was with just two adaptors.
I just thought there may be a technical reason why the software could not see any more than two adaptors.
Thanks again.
Just poorly designed and orphaned software.
Powerline is effectively a generic technology. Netgear doesn't take it seriously. A bit shortsighted given the benefits that Powerline can bring to other devices.
