22shandy
Nov 27, 2012Aspirant
Powerline adaptor & BT Home Hub 3 Problems Roaming
Hi, I have BT Infinity installed with the BT Home Hub 3 but due to the shape and age of our property the wireless connectivity from the HH3 would not reach the other end of the house. As a resul...
jmizoguchi
Nov 27, 2012Virtuoso
problem is not all wifi devices has ability to hop the AP .
google roaming aggressive and you will find such as Win XP etc has setting for threshold.
Also wifi device to hop sometime are in wireless AP side. Most access point devices do have some ability to change the how it behaves when multiple devices are connected.
In your case some of these setting are not available.
I would look open-mesh.com and create better hotspot .
