rbialeck
Sep 03, 2017Aspirant
Powerline adaptor compatible with Orbi
Can a powerline adaptor be used with orbi 50
michaelkenward
Sep 03, 2017Guru - Experienced User
Where do you want it in the chain?
Between the router and the Orbi? Or somewhere else?
rbialeck
Connect to the Orbi satellite and somewhere else in the house.
- michaelkenwardSep 04, 2017Guru - Experienced User
That Orbi seems to be a bit too new for folks to have much real experience, but I have put powerline devices in various places in a network and it usually works in the same way that it would if you just ran a LAN connection between the devices. But it would take a quick test to check that.
Anyone tried it?
- mnspinkSep 21, 2017Aspirant
I have several devices connected through a powerline (Xycel brand), and while they connect, they do not stay connected to the internet for some reason. I had to stop using the powerline connectors.
