rbialeck
Sep 03, 2017Aspirant
Powerline adaptor compatible with Orbi
Can a powerline adaptor be used with orbi 50
rbialeck
Connect to the Orbi satellite and somewhere else in the house.
michaelkenward
Sep 04, 2017Guru - Experienced User
That Orbi seems to be a bit too new for folks to have much real experience, but I have put powerline devices in various places in a network and it usually works in the same way that it would if you just ran a LAN connection between the devices. But it would take a quick test to check that.
Anyone tried it?
- mnspinkSep 21, 2017Aspirant
I have several devices connected through a powerline (Xycel brand), and while they connect, they do not stay connected to the internet for some reason. I had to stop using the powerline connectors.
