TUN11
Apr 07, 2020Follower
Powerline adaptors and security
Hi I bought 2 powerline adaptors and they worked fine so I bought 2 more (this time with plug passthru). I read you can have up to 8 set up in the house. Only 2 are connected I have tried pressing th...
michaelkenward
Apr 08, 2020Guru - Experienced User
Remember, when adding new plugs to an existing network, you need to follow this advice:
>>> Adding a powerline adapter to an existing powerline network <<<
You need only one plug connected to the router.
Beware that advice. People have complained here that they hit a brick wall when they connect a sixth plug to the network. I'm not sure if this applies to all plugs, including the PLP1000.
