neil40
Jul 20, 2011Aspirant
Powerline and Gigabit
Hi I was helping someone try to set up a 3rd powerline with a new Windows 7 PC that has a Gigabit LAN adapter The scenario is that he already had the twin set (don't know the exact models) and one...
jmizoguchi
Jul 20, 2011Virtuoso
any NIC will auto negotiate the speed so either it negotiates at 100base-t or like you did with changing the speed should have helped.
I see many post on devices does not get IP behind the power line.
I would try static IP on win7 pc since you are getting 169 as per detail description of APIPA.
