neil40
Jul 20, 2011Aspirant
Powerline and Gigabit
Hi I was helping someone try to set up a 3rd powerline with a new Windows 7 PC that has a Gigabit LAN adapter The scenario is that he already had the twin set (don't know the exact models) and one...
neil40
jmizoguchi wrote: any NIC will auto negotiate the speed so either it negotiates at 100base-t or like you did with changing the speed should have helped.
I see many post on devices does not get IP behind the power line.
I would try static IP on win7 pc since you are getting 169 as per detail description of APIPA.
Even with a fixed IP it didn't see the Internet etc, just showed a yellow triangle on the network graph symbol in the taskbar
