mkhuh
Dec 15, 2011Aspirant
Powerline AV 500 Network Speeds
I have the following setup: WNR2000v2 router XAVB5004 (adapter + adapter-switch AV 500) 100 Base-T NIC and wire from computer to router Adapter connected to router Powerline utility claims t...
tpcguy
Dec 15, 2011Guide
Hi,
It seems like your network is setup fine, it's just the connection is running through your electrical lines/wires that's why its just 35mbps. The LAN speed from the network is normally 100mbps for home products.
