mkhuh
Dec 15, 2011Aspirant
Powerline AV 500 Network Speeds
I have the following setup: WNR2000v2 router XAVB5004 (adapter + adapter-switch AV 500) 100 Base-T NIC and wire from computer to router Adapter connected to router Powerline utility claims t...
Brandon168
Dec 29, 2011Aspirant
I have not done extensive testing but I thought I would add something to this.
Using the NetGear AV500's, I'm showing 127 Mbit/s up/down in the utility.
I'm getting just under 54 Mbit/s real-world throughput each way.
Boxee Box -> AV 500 -> AV 500 -> Ethernet to Cisco Router -> Ethernet 1 Gbit/s to Core i3 Desktop. (No wireless here)
It could be that the Boxee is the limiting factor. I may plugin my laptop directly later to do more testing.
