Justine53
May 19, 2021Aspirant
Powerline AV500 connection problems
I have just updated my home router as the old one wasnt working. I've got the router up and running without any problems but the powerline adaptors won't reconnect (my wireless network on my laptop s...
- May 20, 2021
So, I have solved it! I had to connect a laptop to one of the adapters then it allowed me to copy the security info from the router over, and bingo, up and running. Problem is, most of my equipment is Mac, which doesn't have ethernet ports, so had to track down a laptop to use! Don't know how would have got it working otherwise! Thanks everyone for their input!
Justine53
Thanks for the quick reply. It's a virgin media one (so not sure what make) but I can connect wirelessly fine to the new router. I have got Powerline AV500 devices. I have connected one directly to the router, and two others in different rooms.
Initially I couldn't get my laptop / phone to find the extenders, but finally they have now appeared with the same name as the router (plus _ext on the end) but they don't accept the password when I try to connect to them
Devices hardwired into the extenders don't work.
May 19, 2021Guru - Experienced User
there are powerline devices and powerline with built in wifi.
You still haven't put what versions you have? AV500 is a spec.
Did you set whatever random versions you have up using wps?
What virgin media router is it? (the label should have model number)
