Justine53
May 19, 2021Aspirant
Powerline AV500 connection problems
I have just updated my home router as the old one wasnt working. I've got the router up and running without any problems but the powerline adaptors won't reconnect (my wireless network on my laptop s...
- May 20, 2021
So, I have solved it! I had to connect a laptop to one of the adapters then it allowed me to copy the security info from the router over, and bingo, up and running. Problem is, most of my equipment is Mac, which doesn't have ethernet ports, so had to track down a laptop to use! Don't know how would have got it working otherwise! Thanks everyone for their input!
michaelkenward
May 20, 2021Guru - Experienced User
As plemans says AV500 doesn't tell us what plugs you own.
Is this the XAV5001? That's the only one that calls itself AV500. Others use labels like AV+ 500. (That's the XAV5601.)
Justine53 wrote:
(my wireless network on my laptop still offers me the name of the old one).
The old wireless network of what? Router?
- Justine53May 20, 2021Aspirant
- michaelkenwardMay 20, 2021Guru - Experienced User
So, the Powerline plugs were working but the rest of the network was not playing ball?
Nice to know that it now works for you. Unfortunately, anyone who turns up here following the Solved tag will be none the wiser. We still do not have any idea about the model of the Powerline plugs you were using. Are they even wifi plugs?
I add this simply to tell them not to waste too much time trying to work out the answer.
- Justine53May 21, 2021AspirantThanks for the slightly patronising response! I have double checked them and all they say on them are
Power line av500. I assume the fact that I can now connect to them over wifi means they are wifi extenders.
