jh321's avatar
jh321
Powerline AV500 Password Reset
I have a powerline AV 500 that works well, but I have lost the password.
Is there a way to get a reminder, or can you tell me how to reset please?
Thank you SO much!
1 Reply
  • schumaku's avatar
    schumaku
    Assuming the product taged is correct - check the XAVB5001 Installation Guide.
    "Press the Factory Reset button for 1 second, then release to return the Powerline adapter to its factory default settings."
    Needless to say, you have to use the Security Button as documented to re-gain a secured powerline network.
