jameskillman
Apr 05, 2013Aspirant
Powerline Connectivity
Pardon the newby question, I want to use powerline adaptors to connect a youview box to a router. I have a house with an extension and 2 separate consumer units (fitted one above the other) in the old...
Retired_Member
Apr 06, 2013Just a thought.
If the two panels share a common feed from utility then it just might work because there really isn't anything to prevent it. I think generally speaking they assume the long service feeds from the utilities would stop it from working, but if sharing a common feed I see no reason why it wouldn't work.
