sideshow255
Mar 05, 2010Follower
powerline device not detected...
After initial setup, i keep on getting an error message "powerline device not detected" on the netgear utility menu; can anyone help me with correcting this? all light are on and green with the first ...
jmizoguchi
May 31, 2010Virtuoso
Abraham12 wrote: I have a 'Netgear HDXB101 Powerline' connected to the O2 Wireless box III and then another 'Netgear HDXB101 Powerline' connected to a Popcorn Hour box in another room. My problem is that the ethernet port on the wireless box doesn't detect my Popcorn Hour .... or any 'Generic device' for that case.
Can anybody tell me how I can make the router detect what's on the ethernet port?
I can't really change any settings (or can I?) if the device hasn't even been detected.
try setup static IP on device side and see if you can make any connection to work
unless the power line device itself is not connecting at all
