KenLark
Dec 28, 2012Aspirant
Powerline Distance
Haven't been able to find a spec for the distance a powerline adapter signal should travel, does anyone know? Apart from the spec, any input on real world distance? Mainly concerned with neighbors bei...
jmizoguchi
Dec 28, 2012Virtuoso
Power line has encryption to it will be protected.
Within the same main circuit it should be safely used
